Discussion topic: I’ve completed a hard drive reset and now I can’t get a signal at all
Message posted on 25 Jul 2024 10:38 PM
We couldn't access recordings or downloads so followed the instructions to complete a hard drive reset and now it say we have no satellite signal
Message posted on 26 Jul 2024 06:40 AM
							Re: I’ve completed a hard drive reset and now I can’t get a signal at all
I did a hard reset too yesterday as advised by customer services and I have exactly the same problem.
Message posted on 26 Jul 2024 07:01 AM
Do you have your own dish or do you have a communal system ?
If you have a communal system and  eset your box the chances are that the LNB type is set incorrectly
In this case you need to check/change the LNB type to SCR - this is in an engineer's menu
To access it :
press Home
Scroll to Settings - but do not press enter/select at this point
Press 0 0 1 in sequence followed by the Enter/ select button
you should now get the engineer's menu
Select the LNB Type & set to SCR if necessary
After changing the LNB type power down your SKY Q box and restart it for the change to come into effect
