Discussion topic: I sataliete signals
This message was authored by: Janis8
I sataliete signals
Sky are sending a new Q box wil this solve the problem
Re: I sataliete signals
Hi @Janis8   It depends on what the problem is.
If your problem is with the dish (cables/LNB/alignment) then a replacement Q box won't fix it...
If the tuners have burnt out then there's a very good chance it will work.
Remember to remove your viewing card before swapping the box and check the power supplies are the same.  (Some versions have an external brick)
