Discussion topic: I recently had a new broadband fitted with BT and was having problems viewing my sky services .
This message was authored by Angpaul1994 This message was authored by: Angpaul1994
Hi, I recently had a new fibre optic broadband fitted with BT and couldn't watch my sky services so needed a sky engineer to come out and try to fix the problem. Two engineers tried to fix it together and although we resolved part of the problem it wasn't completely resolved and I have been left with a remote that can change channels but not control the volume.
Please advise.
Re: I recently had a new broadband fitted with BT and was having problems viewing my sky services .
Please advise.
Hi @Angpaul1994
Do you know if they tried to completely reset the remote?
Try completly resetting your Bluetooth remote.
This message was authored by Babetta This message was authored by: Babetta
Remote can easily be repaired to telly, just hold down 1 and 3 together pointing at the box and follow the on screen instructions for remote setup. As for the new internet it may be worth turning 2.4 ghz capacity off on boxes further away from router, keaving 1, the closest box on. If there are bt dizcs near any sky devices, move them away. As well as other mesh devices lije alexa,hive,firesticks etc.
