Discussion topic: I plugged in my new sky a mini box to my tv but nothing is happening
Message posted on 28 Oct 2023 06:22 PM
My remote has battery's but the box isn't connecting to my tv
Message posted on 28 Oct 2023 07:21 PM
Re: I plugged in my new sky a mini box to my tv but nothing is happening
Hi @sligofarm
Try pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Message posted on 28 Oct 2023 07:22 PM
Thank u for replying I tryed that and it didn't work
Message posted on 28 Oct 2023 07:25 PM
Hi @sligofarm
What didn't work.
Is the Mini box on with green LED?
Message posted on 28 Oct 2023 07:27 PM
It's has been on green and orange when I pressed 7&9 then 1&3 to pair it and nothing happens
Message posted on 28 Oct 2023 07:31 PM
Hi @sligofarm
It needs to be on green when you try to pair the remote.
Also if you have a green led on the mini you must sure that the Television set is switched to the correct HDMI input. ie the HDMI input that is connected to the Mini
Message posted on 28 Oct 2023 07:33 PM
Thanks for helping, I have the pink HBMI cable put into the HBMI IN 1(STB) in my tv
Message posted on 28 Oct 2023 07:41 PM
Hi @sligofarm
And is the led Green on the mini?
And have you made sure the Television set is also switched to HDMI 1? If you are not sure use the TV set remote to cycle slowly through all the inputs.
