1
This discussion topic has been answered Discussion topic: I need to know if our 2nd room box runs off wifi as there are wires along our wall which look like ?
This message was authored by: RemskinC
Wiring running along the skirting, partly under skirt and I need to hide it or get rid before flooring is put down. I'm pretty sure it's from our old virgin system
This message was authored by: Laing1 Answer
Re: I need to know if our 2nd room box runs off wifi as there are wires along our wall which look li
@RemskinC the mini box can run from Wifi or from an ethernet cable connected to the router or main box. If the cable you have found is coax cable and its not connected to your main Q box then it would seem you can remove it
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
