Discussion topic: I need to get Sky TV in another room
Message posted on 19 Apr 2024 02:00 PM
I have 4 Sky Mini boxes and wanted Sky TV in an additional room. What are my options? Can I get Sky Go App via my Samsung TV? Can I get the Sky Go app on a amazon firestick or Apple TV?
Message posted on 19 Apr 2024 02:21 PM
Re: I need to get Sky TV in another room
@MPOWAR4 is the max number of minis you can have although as you probably know you can only watch on 2 at a time. I take it moving one of the existing minis isnt an option and its actually a 6th TV you want sky on?
Message posted on 19 Apr 2024 02:29 PM
That is correct. As I can only watch on 2 minis at one time I wanted to know how I can utilise the Sky Go option if the app is available on a firestick or apple tv for example.
Message posted on 19 Apr 2024 02:52 PM - last edited: 19 Apr 2024 03:32 PM
@MPOWAR Unless you want to specifically keep Q for certain features and your bb would handle it you actually might have a case to look at Stream as that lets you have 6 pucks which you can use all at once. There would be a cost for the pucks though.
Message posted on 19 Apr 2024 04:27 PM
@MPOWAR your options are either moving a mini box or you can watch on an apple TV box a games console or the Sky go app either on a phone/tablet or a laptop which if you have a HDMI out on that you can connect to a TV
You Q box allows you to watch on 2 mini boxes at the same time and 2 tablets/phones/laptops through Sky go as well
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
