Discussion topic: I need help with satellite signal
Message posted on
21 May 2024
07:19 PM
- last edited:
22 May 2024
09:10 AM
by
Kelsingra
Yep! No signal strength here in Grimsby. I can't find any reference to satellite signal issues through Sky account. Any joy with yours?
Moderator note: Changed title to reflect topic more.
Message posted on 21 May 2024 08:30 PM
Re: Sky go suddenly not working on ps5.
Just trying to watch Netflix through my sky account. Every menu on the sky home screen says 'Sattelite signal needed for this service'. I checked the signal strength and it shows X. I have Internet on my phone via Sky WiFi, so I think it's just a satellite problem. I searched for for local Sky problems and ot says none reported.
Message posted on 22 May 2024 10:12 AM - last edited: 22 May 2024 11:14 AM
Satellite reception issues are either with an individual dish, a communal reception system within a particular building, or national (in which case this forum would melt). By definition they cannot be regional or 'local' because the same signal broadcast from orbit falls in the entire country.
The most likely explanation is that your dish connection has failed, and (if it's your own dish) you'll need to book Sky to investigate.
Message posted on 22 May 2024 10:13 AM
Re: I need help with satellite signal
https://www.sky.com/help/articles/sky-tv-no-satellite-signal
Message posted on 22 May 2024 10:58 AM - last edited: 22 May 2024 10:59 AM
Any "local issue" with Sky almost certainly refers to broadband, or maybe Sky Glass/Stream, not Sat TV services.
Message posted on 22 May 2024 11:12 AM
Smashing. Thanks for that, Timmy. I've just checked using that link and it seems OK. I'll be checking if it works later today!
