Discussion topic: I need a boster to help connect my qbox
This message was authored by: Harry5
Almost daily 2nd sky box looses connection with main box
Re: I need a boster to help connect my qbox
Hi @Harry5
Reboot the mini as above.
Failing all of the above if you need a Sky Q WiFi Booster to position midway between your main Q box and the mini and you will need to contact Sky directly.
