Discussion topic: I’m trying to watch something on MTV it states I need to upgrade my subscription through settings
Message posted on 30 Aug 2023 10:17 PM
Keeps stating to upgrade subscription, help suggests to change to SD but option not given
it needs a system update how do I do that without calling SKY as they are now closed
thank you all in advance
Message posted on 30 Aug 2023 10:22 PM
Re: I’m trying to watch something on MTV it states I need to upgrade my subscription through setting
Hi @HWilk
It's quite possible that there is no SD option available.
What exactly are your trying to watch?
Sky Signature includes BoxSets and Entertainment channels only in SD as standard.
Only free to air channels such as BBC, ITV etc are in HD. The Q HD pack is required for all other Sky Signature HD content, including Catch Up in HD, On Demand in HD and BoxSets in HD
If you do not have the Optional HD pack you need to change the Download to SD in All Formats (as HD is the default setting).
So that you do not need to do this every time it’s best to change your Download preference to SD in Home - Settings - Setup - Preferences.
This needs to done on the main Q box.
Then if you want to download any HD content from free to air channels (BBCHD ,ITVHD etc) you can select HD in the All formats tab of the content . This will change the format for that particular download only but still leave your format to SD in preferences.
Message posted on 30 Aug 2023 10:23 PM
Press Home on your Sky Q remote and select Settings, then Setup. Select Preferences, then 'On Demand default download format', and choose SD.
