Discussion topic: I’m getting no satellite signal
This message was authored by: gurmit1
I'm sky isn't working , reset box and still getting no signal ?
Re: I’m getting no satellite signal
@gurmit1  Work through this link https://www.sky.com/help/home/sky-tv/sky-tv-q/fixing-sky-q/fixing-live-tv/no-satellite-signal/articl...  once you get to the end you should be able to book an engineer.
This message was authored by: Shabana11
I reset my box still not getting any signals.
See post #2
Sounds like you need a Sky engineer to check it
This message was authored by: Sp60
Still not getting any signal
@Sp60
No signal or no satellite signal?
If a message is displaying ”No signal” it tends to be from your TV not being on the correct input (check the HDMI cable between the Sky Q box and your TV)
Any “no satellite signal” message relates to your Sky box.
Whenever a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels. If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
