Discussion topic: I keep losing channels ,because of no signal.now its 111
This message was authored by: Rjk360
The channel is cutrently affected by a problem with your satellite signal etc
Re: I keep losing channels ,because of no signal.now its 111
@Rjk360
If a message displays “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
