Discussion topic: I jave a faulty infrared sensor on my mini box
This message was authored by Aidey This message was authored by: Aidey
The infrared sensor on one of the mini boxes is not working so I can't set it up
Re: I jave a faulty infrared sensor on my mini box
hi @Aidey
How do you know it's the mini infrared sensor?
Aidey
Because it's fell into the box and only partially visible
Hi @Aidey
Once paired the mini remote is Bluetooth and doesn't need the sensor.
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the minibox on
Try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes on the remote and follow onscreen instructions to re- pair.
Aidey
Yeah cheers, but I forgot to mention it hasn't been paired to my new broadband, I've just brought a new tv and decided to re pair with the broadband and tv
Hi @Aidey
Remotes are not paired to your Broadband.  They are just paired to your Q box and TV
This message was authored by Chodley This message was authored by: Chodley
Someone has pressed the IR sensor assuming it's a button I guess? I'm sure that happens. Don't think the remote re-pairing with the box can be done without a working IR sensor. New box possibly needed.
