2
This discussion topic has been answered Discussion topic: I have two sky mini boxes and although O can see the tv guide etc, when I select a channel I just ge
This message was authored by: Jo+Fowles
I have two Sky mini boxes. I can see the TV guide etc, but when I select a channel I get a blue screen. I have tried a reset which has failed. I can access apps such as Netflix and they work fine. Settings show network and Sky Q box connection to be all good. Sky Q box is working fine. Can anyone help?
Re: I have two sky mini boxes and although O can see the tv guide etc, when I select a channel I jus
Hi @Jo+Fowles
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
Hi @Jo+Fowles
Avatar for Jo+Fowles
Thank you.
I've re-booted the Sky Q box and the mini boxes are now working.
Thanks for the help. Much appreciated.
