Discussion topic: I have to return my sky q boxes and router , I have been sent 2 labels with different addresses???
This message was authored by: debbie+dance
I have been sent 2 return labels with 2 different addresses so don't know which address to use for which item ? There are no instructions
Re: I have to return my sky q boxes and router , I have been sent 2 labels with different addresses?
Hi @debbie+dance
See the following link for all Sky returns information.
https://www.sky.com/help/articles/return-tv-broadband
If necessary you can use you own Packaging and also print your own labels.
Ensure that you keep proof of posting as the Sky return system handled by Unipart has delays and is not as reliable as would be desired.
Avatar for debbie+dance
I have looked there already , it doesn't tell you
Hi @debbie+dance
The following is in the link I posted
How to return your equipment
  1. Package your equipment, ensuring all the original equipment is included
  2. Visit Royal Mail returns, select the shape of your package and enter your details. Any address fields should be filled with your details, not Sky's.
  3. When you’ve finished, you’ll receive an email containing your return label.
  4. Print and attach it to your package then take it to your local Post Office, depot, parcel Postbox or arrange a home collection.
    • Don’t have a printer? You can also choose to print off the returns label at your local post office. You'll find how to do this on the Royal Mail website after you create your label.
  5. Keep the receipt as proof of return and use it to track your return online.
I've got the return labels but they are both different addresses , it doesn't tell you which address is for sky box and which address label is for router
Hi @debbie+dance
I gave you the link so you can get new labels to confirm the correct return addresses
This message was authored by: Debs236
Just had to ring Sky to confirm that the Nuneaton address is the correct address.  Put all equipment in one box and send there. 👍
This message was authored by: Cardifftwilite
I've the same problem, but I have to packages to return, 1 box isn't enough
@Cardifftwilite
You can use any packaging as long as it’s secure and you may want to put a note inside with your account number and a list of equipment that is included. This link explains about how to receive an email with your return labels through Royal Mail.
Keep your proof of posting safe and indefinitely and if you use Royal Mail’s collect from home service, keep a record of the tracking number.
Hi @Cardifftwilite
Either use you own packaging or ask for more from Sky.
If necessary you can print your own Royal Mail labels.
If you are using Royal Mail ensure that you keep proof of posting as the Sky return system handled by Unipart has delays and is not as reliable as would be desired. If you arrange for Royal Mail to collect it you will get a tracking reference which can be used to trace the package online.
Regardless of how they are being returned include your Account number and a Note with the returned items listing the contents of each and any package. Best option is to also take a photo of the contents once they are packed.
Hi, thanks for the response, they sent me two boxes, but 2 labels with different addresses.
I will try the royal route.
thanks
@Cardifftwilite
They end up at the same warehouse.
