Discussion topic: I have three sky boxes how do I cancel two I no longer need ?
This message was authored by: Ed87a
I currently have three sky q boxes set up, I no longer need two of them. How do I cancel the extra two and arrange a return of them. ?
Re: I have three sky boxes how do I cancel two I no longer need ?
@Ed87a
Sky TV
~ To remove part of your package, in your case Sky Multiscreen, you will need to contact Sky. You can’t do it via the forum. Select ‘Need more help’ at the bottom of the following link which will lead to contact details.
https://www.sky.com/help/articles/cancel-sky-tv#contact-leave
(Make sure the flag in the bottom right corner is the correct one ie; UK or ROI).
UK customer ~ The link may include an email link and also a Message Us option (which is normally available between 9am and 7.30pm).
ROI customer ~ it’s only by calling Sky Ireland or writing in.
If you cancel correctly you should receive a confirmation email from Sky.
If you’re cancelling Multiscreen don’t forget to keep you proof of posting indefinitely when you return the mini boxes. Return packaging will be sent out towards the end of your notice period.
