4
This discussion topic has been answered Discussion topic: I have switched on my Sky Q box and TV but the TV states "connecting to your sky q box" continuosly
This message was authored by: twizzle1
I have switched on my Sky Q box and TV but the box does not connect to the TV. The HDMI cable is firmly plugged into both Box and TV. I have put new batteries into the Sky Q remote. I have tried various suggested solutions, including switching off the Sky Q plus button for 5 seconds, but to no avail.
Avatar for twizzle1
Level 3 icon
This message was authored by: twizzle1 Answer
Re: I have switched on my Sky Q box and TV but the TV states "connecting to your sky q box&&
The problem has been fixed after I contacted Sky Customer Service. The Operative I could not fault. He guided me through the menus and fixed the problem. I suggest if you ever have a problem with Sky contact Customer Service and hope you get someone who is as good as the Guy who fixed my problem.
Re: I have switched on my Sky Q box and TV but the TV states "connecting to your sky q box&quot
Hi @twizzle1 Place your tV on standby, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on to reboot.
Avatar for twizzle1
Level 3 icon
I done what you said and my 2nd sky +HD box started working fine. 5 minutes later the original problem returned. I will give it another go tomorrow morning. Thanks again for the info.
@twizzle1 wrote:
... and my 2nd sky +HD box
You've posted in the Q forum?
Avatar for twizzle1
Level 3 icon
Answered - Go to Answer
