Discussion topic: I have sky q , everything works fine except TNT sports
Message posted on 18 Oct 2025 05:31 PM
Why does TNT SPORT PIXELATE WHEN ALL OTHER CHANNELS WORK FINE?
Message posted on 18 Oct 2025 05:40 PM
Re: I have sky q , everything works fine except TNT sports
Hi @Adman1 You need to get your satellite dish alignment checked. TNT Sports always appears to be the first the go.
Message posted on 18 Oct 2025 05:50 PM
I agree with @MightyQuinn
Firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels
