Discussion topic: I have sky dish and q box but I can’t connect to internet even though there is a signal in the hous
Message posted on 25 Feb 2024 06:57 PM
I have sky q and a dish
i can access this but can't contact to internet and there is a good internet signal from the router in the same room
help
Message posted on 25 Feb 2024 07:23 PM
Re: I have sky dish and q box but I can’t connect to internet even though there is a signal in the
help
Hi @Griffiths
If on Sky broadband first reset your broadband router by holding Reset on the back until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
