Discussion topic: I have not been able to see TV programmes for 2 days
Message posted on 24 Jan 2025 04:33 PM
My TV spontaneously stopped 2 days ago - one minute I was watching The Good Fight, then the screen filled with a colourful graphic, and I have not been able to asee any TV prograames since then.
I have done all the usual switch off switch on checks
Maybe there is a button on my remote I need to use.
Message posted on 24 Jan 2025 07:43 PM - last edited: 24 Jan 2025 07:43 PM
Re: I have not been able to see TV programmes for 2 days
Can you even get the Sky menu up?
Message posted on 24 Jan 2025 07:53 PM
Hi @CambRHH
What colour is the led on the front right of the Q box?
Green or Amber?
Message posted on 24 Jan 2025 07:55 PM
Hi @CambRHH Does it work with your terrestrial aerial (Freeview)?
Message posted on 24 Jan 2025 11:09 PM
It was green.
it seems to have become Amber today
Message posted on 24 Jan 2025 11:11 PM
And if you press the power button it doesn't go green?
power cycled it at the wall?
Message posted on 24 Jan 2025 11:13 PM
No - since the programme I as watching was suddenly replaced with a blue screen with the words Here We Go!! across the top, that has been mostly what I see .
Message posted on 24 Jan 2025 11:14 PM
No, nothing except the blue screen that has appeared - it is all silent
Message posted on 25 Jan 2025 06:58 AM - last edited: 25 Jan 2025 07:00 AM
@CambRHH wrote:No, nothing except the blue screen that has appeared - it is all silent
I think that was a reply to me? Forum doesn't make it clear unless you hit the " bbutton to quote / insert the post you hit reply on.
I meanr the power light on the box going green, not the tv screen.
and I asked if you have tried power cycling it at the wall.
Message posted on 25 Jan 2025 08:48 AM
The LED light has mostly been green for over 2 days.
it went amber towards the end of yesterday - not clear why.
power cycling is a term I have not heard before. If you mean have I switched everything off and on, then yes, I have done that - no change to the situation.
Message posted on 25 Jan 2025 09:25 AM
Hi @CambRHH What happens when you press the power button on the box (not the remote)?
Message posted on 25 Jan 2025 12:43 PM
I think it might be properly dead
