Discussion topic: I have no sky signal So what’s going to happen th I’ve switched on Sky boxes and stole nothing
This message was authored by: Kyle24
Did you understand that my sky box the two of them? I switched them off switched them back on and I'm not receiving the sky signal why is this?
Re: I have no sky signal So what’s going to happen th I’ve switched on Sky boxes and stole nothing
@Kyle24
If you’re seeing a message displaying ”No signal” it tends to be from your TV, such as possibly not being on the correct input (check the HDMI cable between the Sky Q box and your TV)
Whenever a “no satellite signal” message is displayed, that relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels. If you’re on a communal dish you may initially need to liaise with your landlord or building management company who deal directly with their approved engineers.
