Discussion topic: I have no satellite signal
This message was authored by: FP3
When I switch my sky q box on there is a message to say there is no satellite signal
Re: I have no satellite signal
@FP3
Any message displaying “no satellite signal” relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with you building management company / landlord who will have their approved engineers to contact.
Note: A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
