Discussion topic: I have no WiFi signal going to my Sky QBox.
This message was authored by: Nige14
I have checked the Sky Service Checker and it is telling me that my Q box is not picking up my WiFi signal. As such I cannot watch any TV Channel or recordings or anything.
Re: I have no WiFi signal going to my Sky QBox.
Hi @Nige14
Having no Wi-Fi wouldn't affect your ability to watch live TV channels or your Recordings.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
This message was authored by: jules1344
I am having the same problem  my sky Q box is not connecting to wifi  .I have rebooted my router and chekeed all the cables and settings and it still comes back with the same message .
