Discussion topic: I have lost signal from my sky signal booster to my mini box also my main sky box keeps dropping the
Message posted on 19 Sep 2024 01:29 PM
My main sky box keeps dropping the WiFi, my mini box has lost signal from the signal booster
Message posted on 19 Sep 2024 01:51 PM
Re: I have lost signal from my sky signal booster to my mini box also my main sky box keeps dropping
Hi @Anthony672
Try reconnecting your main Q box.
Once the main Box is back up and running reconnect your Q booster (assume this is located between main box and mini)
- With the booster power and wireless lights on green.
- Hold the WPS button on your booster for 3 seconds until it flashes amber. Then hold the WPS button on the front of your Q box for 3 seconds until it flashes amber - You'll need to do it within 2 minutes.
- After a few minutes, the connected light will turn green.
Then to connect your mini box carry a Network Reset found in mini box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by by WPS.
You will be asked to press the WPS button on the nearest Sky Q device (Not on the mini box as the Network reset will start the mini box WPS automatically). Assuming the booster is the nearest device you press the WPS on that.
