Discussion topic: I have lost all recordings on skyq box. Tried recording another program but has failed to record.
Message posted on 09 Apr 2024 01:13 PM
I have lost all of my recordings on skyq box
Message posted on 09 Apr 2024 01:17 PM
Re: I have lost all recordings on skyq box. Tried recording another program but has failed to record
Hi @GraemeR
First try rebooting your Q box.
Failing this and you still cannot make new recordings,
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Don’t forget to keep your viewing card from the failed box if you order a replacement. Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
