Discussion topic: I have just purchased multiscreen and wondered how I get another additional box?
Message posted on 23 Aug 2024 12:46 PM
I have received one additional sky Q box for my multiscreen but I need another one for my sons bedroom. How do I get one? Thanks
Message posted on 23 Aug 2024 12:48 PM
Re: I have just purchased multiscreen and wondered how I get another additional box?
Speak directly to Sky @Johnbee72
Also bear in mind
You can have up to four minis installed on loan each subject to a one off upfront charge and all under by one single Q monthly Multiscreen subscription
However only two minis can be used simultaneously on all 2 TB boxes and the 1 TB UHD Main boxes to watch Sky Q content.
The original 1 TB non UHD box (32Cxxx) only permits the use of one mini at a time.
If Sky Apps are already being used on some of the minis these will not normally be counted as in Q use and therefore can be used in addition to the above limits.
See the following link for the Versions of main Q box referred to above.
https://www.sky.com/help/articles/sky-software-updates.
Message posted on 23 Aug 2024 12:49 PM
@Johnbee72 Give sky a call and they will order for you
