1
This discussion topic has been answered Discussion topic: I have internet into my property but my sky’q won’t connect
I have internet into my property I have checked it all but my skyq box and mini boxes won't connect.
Re: I have internet into my property but my sky’q won’t connect
Hi @Anonymous
Wait until the router is completely back and running and then try a Network Reset on the main Q box found in Q box Home - Settings - Setup - Network.
Hi @Anonymous
