15
This discussion topic has been answered Discussion topic: I have installed new fibre broadband and now I can't get an internet connection on my skyq mini boxe
This message was authored by: BrucieC
I recently changed broadband supplier to a fibre operator. The broadband works fine on all my devices including my skyQ box however neither f my 2 mini boxes has an internet connection to the main box. All the help programmes say use the handset to go to Home, etc, etc but without internet the handset doesnt work! Ive tried rebooting, refreshing and resetting with no result. can anyone help? Obviously Sky are impossible tocontact to discuss even by using their chat device. Help
Re: I have installed new fibre broadband and now I can't get an internet connection on my skyq mini
@BrucieC wrote:
Hi oldfella,
Thanks for all the advice, I did manage to get one of the mini boxes working this morning with your help. As I think you suspected, the new wifi does not have the range of the Sky broadband and that was part of the problem. I'm now looking at wifi boosters or range extenders to see if they will give me a better coverage as I am also losing connection with my audio boxes and printer! Thanks once again.
Hi @BrucieC
Bear in mind that Q mini boxes will only connect to Sky Q boosters and not 3rd party boosters
hi @BrucieC
The remote does not rely on the internet to work so you must have a different problem.
Try resetting the Remote by pressing & holding 7 & 9 together until the red led above the SKY logo button flashes 4 times
Once it is reset it works in IR mode and at that point & until it is paired needs direct line of sight of the SKY Q box..
Was your  broadband SKy or a different supplier  ?
Hi @BrucieC
Exactly what happens when you reboot your Mini box as follows:-
To reboot press Standby on your mini remote (if the box responds to the remote), and then switch off and unplug at the mains.
Avatar for BrucieC
Level 2 icon
Hi OldFella, Thanks for the response which unfortunately seems to have dissapeared when I went to respond!
My problem with what you say is that the minibox remote does not connect to the minibox. Pushing the on/off button which is also the standbye button has no effect, I think that this is because there is no internet there. (I have replaced the batteries with new ones!)
I have tried resetting everything on the main SKYQ box but this has no effect on the mini box. In fact on System status it says that the mini boxes are connected.
Hi @BrucieC
Not sure that you are pressing the Standby button on the mini box (not on the remote).
The Amber/Green led on the front right of the mini is the box standby button.
Have your tried pressing the Amber led on the mini (about one minute after the led turns Amber after the reboot)?
Avatar for BrucieC
Level 2 icon
pressing 7&9 worked! I'm now just waiting for the blue screen, OK got it! now waiting for it to connect. Oh no! Message saying no internet connection - going to try your other suggestion if I can find it - for some reason the last message doesn't follow the reply
Avatar for BrucieC
Level 2 icon
Hi OldFella, It all seemed to be working - I switched the unit off, waited 30 seconds, completed 3 questions on the screen saying that this was a new broadband and now I have been waiting for 4 minutes while the minibox is resetting your network connection.
Previously I was with sky broadband
Hi @BrucieC
Any chance you can try the reboot again with the mini (and TV) nearer to the main Q box?
Avatar for BrucieC
Level 2 icon
I really appreciate your help - you have got me further than anyone in the last 2 days although I think this is not going to work as the 2 minute wait to reset is now almost 10 minutes
In which case you may need to be aware that if you are now not with SKY broadband the minis don't connect to your wifi but connect to a wifi network generated by the SKY Q main box so you may find coverage different
Avatar for BrucieC
Level 2 icon
I will reboot and try to move boxes closer together but have to leave now I will try again in the morning, thank you so much
Hi @BrucieC
Make sure that you move the mini which is the one nearest to the main Q box (when it is in its normal working position.)
Avatar for BrucieC
Level 2 icon
Hi oldfella,
@BrucieC wrote:
Hi oldfella,
Hi @BrucieC
Avatar for BrucieC
Level 2 icon
Hi oldfella,
I didn't know that about the boosters. Problem is that my security cameras and wifi speakers need a boost. Obviously more thought needed. It's great when everything works but a nightmare for non technical people to set it up!
