Discussion topic: I have got a new mini box and it says its connected to my skyq box and the Internet but won't work
This message was authored by: Peter.2112
Re: I have got a new mini box and it says its connected to my skyq box and the Internet but won't wo
Hi @Peter.2112
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
