Discussion topic: I have giganet wifi
This message was authored by: Kurtdaflirt
I have giganet wifi
Since getting giganet my sky q box won't stay connected to it, randomly it will disconnect from it and I have to re set up
Re: I have giganet wifi
The Q will only connect to a 2.4GHz signal if using non-Sky ISP.
Check the router doesn't steer to 5GHz and perform a network reset on the Q.  (Use WPS to connect if possible)
