Discussion topic: I have four Sky Q mini boxes and none of them are responding to their remote controls.
This message was authored by: Caja1
I have four Sky Q Mini boxes and none of them are responding to their remote controls
Re: I have four Sky Q mini boxes and none of them are responding to their remote controls.
@Caja1
Fully reboot the main Q box (remove and return power) and then do the same with each Mini in turn.
Hi @Caja1
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
With the mini box on with green led try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
