Discussion topic: I have bought a new Sky q remote and the volume control isn’t working
This message was authored by: Bellwhiff
I have bought a new Sky q remote and the volume control is not working
Re: I have bought a new Sky q remote and the volume control isn’t working
hi @Bellwhiff
May I suggest you try a reset of your remote:
Press & Hold the 7 & 9 until the remote's light (red LED above the SKY logo button) flashes 4 times
Then press 1 & 3 together to go through to pair with the box and your TV - make sure it has line of sight of the box as until it is paired it uses Infrared
https://www.sky.com/help/diagnostics/sky-q-remotes/setting-up-remote
