Discussion topic: I have been away from home for four months and My viewing card is not working
This message was authored by: TrevorGalbraith
Re: I have been away from home for four months and My viewing card is not working
@TrevorGalbraith
You aren’t contacting Sky Customer Services by posting on here. This is primarily a customer to customer forum.
Has your Sky Q box been turned completely off in that 4 months?
Hi @TrevorGalbraith
First check that your viewing card is correctly inserted. Viewing card is in the right hand end of the box.
If it is in correctly there is not enough of it sticking out to grip and remove it.
Push it fully in and it will pop out slightly enough so you can remove it.
Make sure that it is in chip side up and chip end in first. Push it gently fully in and you should feel a slight click when it is engaged. If it has popped out enough to remove it is not located correctly.
If you are satisfied that it is in correctly
Try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
