19 Apr 2023 12:49 PM
I have 3 mini boxes. I know i can only watch 2 at a time. One of my boxes keeps dispaking a message saying Technocal fault. Also when tring to watch the other two boxes with the third disconnected one of the boxes says too many boxes in use and effectively I can onlly watch the main box and 1 mini box. Tried re set router and re set box already can anyone tell me what to do
19 Apr 2023 12:58 PM
Hi @Upton1
Have you tried a Reset Settings in the main Q box hidden menu.
19 Apr 2023 01:04 PM
I will give it a try when I am home later
