Discussion topic: I have a WiFi connection on my phone but my tv says I don’t have an internet connection
This message was authored by Paulf2 This message was authored by: Paulf2
My Chanel's are working but I can't get any catch up tv
Re: I have a WiFi connection on my phone but my tv says I don’t have an internet connection
Hi @Paulf2
