Discussion topic: I have a Sky Q Box And UHD Tv try setting it to UHD message comes up error UHD 031
Message posted on 12 Mar 2023 12:08 PM
I have a Sky Q Box my TV is a Panosonic
UHD I've gone in to the picture Resalution to. Change the the setting it says find it for me the screen goes blank
the says Error UHD 031 help?
Barbara May
Message posted on 12 Mar 2023 12:10 PM
Re: I have a Sky Q Box And UHD Tv try setting it to UHD message comes up error UHD 031
Barbara May
Hi @peregalli47
See if the following link helps
Message posted on 12 Mar 2023 01:04 PM
@peregalli47 make sure the tv's hdmi the SkyQ is connected to is set to recieve HDR:
- Press [AV] button to select HDMI input.
- Press [Menu] button to display Main Menu.
- Select "Setup" in Main Menu.
- Select "HDMI HDR Setting" and press [OK]
- Select the HDMI input connected the HDR equipment and press [OK]
