Discussion topic: I have a BT compatible socket on my wall but it has just one hole I don't know if adpotor will be ne
This message was authored by Vicky322 This message was authored by: Vicky322
This message was authored by Ecosse This message was authored by: Ecosse
Re: I have a BT compatible socket on my wall but it has just one hole I don't know if adpotor will b
Hi @Vicky322
What is it exactly you're asking about?  What is your issue/query?
FYI, SKY Q does not plug in to older BT phone wall connections anymore, just needs access to the internet via your broadband router, either on Wi-Fi or ethernet cable.
Samsung UE49MU7070XX - Samsung MS550 Soundbar+ with 9000S Rears
Sky Q 2Tb + 3 Minis - BT Full Fibre 900
Vicky322
I received a mail from sky asking I should check if I have a BT compatible socket on my wall if not I should call them
Hi @Vicky322,
I'm assuming you're either about to get SKY broadband, or SKY TV + Broadband?
In order for you to actually get broadband you need access to a simple phone line, for ADSL broadband, for Fibre Broadband, there's usually a new faceplate fitted.  As long as you have one of the sockets mentioned here, you should be OK to progress.
