Discussion topic: I have Sky q and sky q mini boxes. When I plug the mini into the ethernet I lose on demand
This message was authored by WebbieJ This message was authored by: WebbieJ
When my main sky q box has full Wi-Fi connection and I connect the mini via the Ethernet my main sky q box loses all on demand services and the the 2 sky q boxes won't connect. I never had this issue when I had sky broadband, this only happened now I have bt broadband.
This message was authored by Addie15 This message was authored by: Addie15
Re: I have Sky q and sky q mini boxes. When I plug the mini into the ethernet I lose on demand
Posted by a Sky employee
This message was authored by bob1234 This message was authored by: bob1234
@WebbieJHave you set it up again since you changed to BT as 3rd party ISPs connect very differently to Sky. If you have any BT discs make sure you are not trying to connect to them by WiFi.
Also the mini boxes using Sky's mesh can clash with BTs 5Ghz channel if they are both on channel 36 so move the BT 5Ghz channel as far away from this as possible.
Here is information on how to set up Q devices, if you want to look through it again.
https://www.sky.com/help/diagnostics/setting-up-sky-q/what-sky-equipment-do-you-have
