4
This discussion topic has been answered Discussion topic: I have 2 Sky Q miniboxes, one won't turn on and has a constsnt red light
This message was authored by: JohnnieC
Sky Q box plus 2 sky Q mini boxes. One of the mini boxes won't turn on and has a constant red LED. I have completed all the resets ECT many times but still won't turn on, any ideas?
Re: I have 2 Sky Q miniboxes, one won't turn on and has a constsnt red light
@JohnnieC wrote:
Oldfella, thanks for the quick reply... Unfortunatly this still doesn't work. I have a constant red LED on the front and all the various resets do nothing.
Hi @JohnnieC
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Hi @JohnnieC
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
Try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Avatar for JohnnieC
Hi @JohnnieC
Avatar for JohnnieC
Received new mini box today... thanks Sky
