Discussion topic: I had sky q box fitted today. I am trying to download a programme and I am getting a message at the
Message posted on 05 Apr 2024 06:58 PM
I had sky q box fitted today. I am trying to download a programme and I am getting a message at the top of the screen saying I need to
Upgrade to watch.
I can see there are different formats. If I opted for standard definition and I get another message saying there is a technical issue and to try again later
Message posted on 05 Apr 2024 08:18 PM
Re: I had sky q box fitted today. I am trying to download a programme and I am getting a message at
Upgrade to watch.
@JANNIEJB try rebooting your router when that is up and running rebootyour main Q box ie
then try downloading in SD
The default download setting is HD so try changing the format to download in SD
you can change the default to SD by Pressing Home on your Sky Q remote and select Settings, then Setup.
Select Preferences, then 'On Demand default download format', and choose SD.
