Discussion topic: I had a new hub & now i cant get my mini box to turn on or the remote to respond
Message posted on 17 Jun 2024 07:20 PM
I tried to set up my mini box after getting a new hub , initially the box still worked but now i have no response from the box or remote
Message posted on 17 Jun 2024 08:14 PM
Re: I had a new hub & now i cant get my mini box to turn on or the remote to respond
@utica Have you tried rebooting your main Q box ie
then
reboot the mini box
if the remote still doesnt work
Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 20 Jun 2024 10:49 PM
All sorted now thanks
