Discussion topic: I got a new q box yesterday and today i have reset it twice and now every other channel is no satell
Message posted on 27 Jun 2023 08:11 PM
I received a new q box yesterday and today I have reset twice and every other channel is saying no satellite signal.
Message posted on 28 Jun 2023 07:52 AM
Re: I got a new q box yesterday and today i have reset it twice and now every other channel is no sa
do you have your own dish or are you fed by a communal system ?
If fed by a communal system after a reset, you may need to check/change the LNB type to SCR - this is in an engineer's menu
To access it :
press Home
Scroll to Settings - but do not press enter/select at this point
Press 0 0 1 in sequence followed by the Enter/ select button
you should now get the engineer's menu
Select the LNB Type & set to SCR if necessary
After changing the LNB type power down (switch off at mains or unplug) your SKY Q box and restart it for the change to come into effect
