Discussion topic: I get sound but no picture
This message was authored by: Charliew90
On screen it says hdmi no source but everything is connected and I am getting sound.
if I plug my laptop via hdmi to the projector I get sky via sky go
Re: I get sound but no picture
@Charliew90
That might suggest the Sky box is outputting a signal at too high a resolution for either the projector or the HDMI cable.
Is the sound coming from a different device?
Avatar for Charliew90
It comes via a TV box into remote speakers and woofer
What is a "TV box"?
It is an onkyo av receiver
Ok so that term I do recognise 🙂
Can it handle 4k?
It always has done just stopped working suddenly. I suspect that the video card may have stopped working?
Hi @Charliew90   Have you tried Sky Q box direct to TV as a test? I should say, power reboot the Sky Q box first.
No sadly not as I don't have a TV. I might try that if I can borrow one
Same theory to the projector though
and try the home-1080-home thing to drop the res in case that's an issue
