Discussion topic: I get sound but no picture
Message posted on 21 May 2025 09:00 PM
On screen it says hdmi no source but everything is connected and I am getting sound.
if I plug my laptop via hdmi to the projector I get sky via sky go
Message posted on 21 May 2025 09:41 PM
Re: I get sound but no picture
That might suggest the Sky box is outputting a signal at too high a resolution for either the projector or the HDMI cable.
Message posted on 22 May 2025 05:21 AM
Is the sound coming from a different device?
Message posted on 22 May 2025 07:07 AM
It comes via a TV box into remote speakers and woofer
Message posted on 22 May 2025 07:33 AM
What is a "TV box"?
Message posted on 25 May 2025 03:14 PM
It is an onkyo av receiver
Message posted on 25 May 2025 05:16 PM - last edited: 25 May 2025 05:16 PM
Ok so that term I do recognise 🙂
Can it handle 4k?
Message posted on 25 May 2025 06:16 PM
It always has done just stopped working suddenly. I suspect that the video card may have stopped working?
Message posted on 25 May 2025 06:18 PM - last edited: 25 May 2025 06:19 PM
Hi @Charliew90 Have you tried Sky Q box direct to TV as a test? I should say, power reboot the Sky Q box first.
Message posted on 25 May 2025 06:20 PM
No sadly not as I don't have a TV. I might try that if I can borrow one
Message posted on 25 May 2025 08:20 PM - last edited: 25 May 2025 08:21 PM
Same theory to the projector though
and try the home-1080-home thing to drop the res in case that's an issue
