Discussion topic: I get message you have reached maximum number of q boxes. I have a subscription for five.
Message posted on 21 Nov 2023 05:08 PM
Maximum number of q boxes permitted. I have subscription for five.
Message posted on 21 Nov 2023 05:10 PM - last edited: 21 Nov 2023 05:11 PM
Re: I get message you have reached maximum number of q boxes. I have a subscription for five.
Hi @Allinspired
Normally Sky will only allow a maximum of 4 minis. Only one Main Q box is permitted per account address.
You can have up to four minis installed on loan each subject to a one off upfront charge and all under by one single Q monthly Multiscreen subscription
However only two minis can be used simultaneously on all 2 TB boxes and the 1 TB UHD Main boxes to watch Sky Q content.
The original 1 TB non UHD box (32Cxxx) only permits the use of one mini at a time.
If Sky Apps are already being used on some of the minis these will not normally be counted as in Q use and therefore can be used in addition to the above limits.
See the following link for the Versions of main Q box referred to above.
https://www.sky.com/help/articles/sky-software-updates.
Subject to the above limits Sky Q minis can be used completely independently of the main Q box and the same or different program or recording can be viewed on each Q box. Even if viewing the same content it is completely independent and can be viewed at the same or different point.
Minis can do all the features same as the main Q box and can set or delete recordings on the main Q box hard drive. There is one single storage area on the main Q box with no profiles and no indication of which Q box has set a recording. (Unlike Sky+HD Multiroom which has independent storage and planners).
It should also be remembered that minis cannot view UHD recordings or content.
Message posted on 21 Nov 2023 05:18 PM - last edited: 21 Nov 2023 05:19 PM
Sky will loan five Q boxes: the main box and four Minis. As @oldfella indicates, the main Q box and any two Mini boxes can be in use at the same time: that's been a fundamental limit since Q was released in early 2016.
If you want five screens in simultaneous use with Sky content you'll need to investigate Sky Stream (and have at least 'Ultrafast 1' broadband)
