Discussion topic: I don't want to talk to other customers with issues I want to talk to sky!
This message was authored by: Mel25
My sky mini box isn't working. I don't want to read about other faults other customers are having, I want to talk to sky to fix tje problem. I pay enough for the service, why is there no customer service?
This message was authored by: Mark182004
Re: I don't want to talk to other customers with issues I want to talk to sky!
This is a community forum. Contact sky direct for the best help.
https://www.sky.com/help/home?DCMP=knc-google-na-0helpsky-skycontact0_contactsky&gad_source=1&gbraid...
@Mel25 as @Mark182004 says this is a customer helps customer forum
not knowing what you have tried then the most common thing to try is
rebooting your main Q box ie
then
when that is up and running
reboot your mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
@Mel25
If you definitely need to contact Sky, (and as long as your services aren’t restricted) then if you already have a Sky Mobile or a Sky Talk landline call free by dialling 150, otherwise you can use:
UK customers: Scroll down and click on ‘Need more help’ and it provides a 0333 number.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ and it provides a 0818 number.
(The forum doesn’t allow us to type the numbers in full).
You will find that similar to calling other large companies the start will be automated which may also try to send you back to the forum.
Note: We were informed on the run up to Christmas the lines were busier than usual and that’s likely to be worse over the holiday period.
The phone line will try to suggest you come here but it will also let you queue to speak to someone.
