Discussion topic: I do t get any volume from the box it happens on and off
This message was authored by: 2Jas02
can't get volume working from box it happens on and off
Re: I do t get any volume from the box it happens on and off
Hi @2Jas02
First try the different options in
Home - Settings - Setup - Audio Visual .
Try  Normal and Dolby Digital.
If you still have an in issue after trying the different settings
