2
This discussion topic has been answered Discussion topic: I changed my BT router yesterday. Set up SkyQ box on main TV ok but mini box won’t. Connect
This message was authored by: Littledot
error message MR104. Settings on main box say internet connection OK and I've tried reactivating mini box.  Tried turning everything off and on again! Any help would be appreciated . I'm not a techy person!
Re: I changed my BT router yesterday. Set up SkyQ box on main TV ok but mini box won’t. Connect
Hi @Littledot
Reboot the mini as above.
Hi @Littledot
Avatar for Littledot
Level 0 icon
Thank you for your very detailed instructions Oldfella.  I've tried them but still can't get a connection.  I'm finding Sky not very helpful so I think I'll have to call out an engineer.
