Discussion topic: I cant get tv channels just keeps saying waiting for tv schedule an my recordings keep failing
This message was authored by: Nua5h
I can't get tv channels keeps saying waiting on tv schedule an recordings keep failing
Re: I cant get tv channels just keeps saying waiting for tv schedule an my recordings keep failing
@Nua5h Have you tried rebooting your main Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Hi @Nua5h
