Discussion topic: I cant get my sky q remote to pair with the tv. I have tried 7&9 and 1&3 to no avail. Please help!
Message posted on 30 Apr 2024 05:55 PM
Message posted on 30 Apr 2024 06:05 PM
Re: I cant get my sky q remote to pair with the tv. I have tried 7&9 and 1&3 to no avail. Pl
@Kia1 wrote:
@Kia1 Have you tried rebooting your main Q box ie
then
Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
@Kia1 wrote:
Hi @Kia1
First try rebooting your Q box.
When the box is completely back up and running
Message posted on 30 Apr 2024 06:07 PM
Thanks for the reply guys, I've tried to do those things. I'm still getting the same message unfortunately
Message posted on 30 Apr 2024 06:08 PM - last edited: 30 Apr 2024 06:09 PM
