Discussion topic: I cannot get itv but every other channel is fine it’s saying no satalite signal ???
Message posted on 20 Sep 2024 10:28 AM
Cannot get itv it's saying no satalite signal but every other channel is fine ??
Message posted on 20 Sep 2024 10:40 AM
Re: I cannot get itv but every other channel is fine it’s saying no satalite signal ???
@EdwardPercival
If a message displays “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
